Using the Material skin.. About %70 of the artist images are incorrect. They usually start out incorrect in the normal Daphile WebUI as well. However, that seems to sort itself out after an hour or so. Not so on the material side. Nothing I've tried fixes it. Deleting cache on chrome (desktop and phone) gets it close. There is always still a few incorrect and or double still. A rescan can make it a little better, or just **** it up again sometimes. Even starting from fresh install... multiple times.. does nothing 🙁
I am using a custom dir with my preferred artist images.
Something else. Minor, but I cannot make the setting for "Database memory config" stick to Max. It always reverts back to high. Actually most of the setting in the performance settings page fail to stick. Server or complete hardware restart does nothing.
I also have a question. What is the RT version of the distro for?
Cheers 😀 😀
The attached image shows an example. Been farting around with it for 2 days now. So unbelievably annoying :'( 😡
Cheers 😀 😀
If you are having issues with the Material skin then contact the developer Craig Drummond. There is a link within Daphile. or
https://github.com/CDrummond/lms-material/issues
https://github.com/CDrummond/lms-material/wiki
https://cdn.statically.io/gh/d6jg/material-documentation/master/html/Material Skin.html
