I just received a used new 2017 Intel NUC7PJYH (with an optic sound port 1/8).
-I try to swap my Daphile already installed and working HD in the NUC. I received a error message : no device bootable. I set the Bios in different way, with Linux setting without automatic on graphic..., I reset to default, nothing to do. I can boot with this HD a Lenovo micro and a old Dell ATG.
- I reinstalled fresh the last version of Daphile, nothing change, always the same error message.
-I try to install Linux Mint cinnamon v. 18 and the NUC was working very well. I booted also from my USB key.
Regards,
Jean
Regards,
Jean
Regards,
Jean
Solution may be found here: https://www.daphile.com/download/DaphileInstallation.pdf, section 9.1/9.2
