Daphile doesn't work anymore and it's impossible to install again
Hi everybody,
I have installed Daphile (version 20.12-x86_64) on my mini PC (MINISFORUM UM350 Mini PC AMD Ryzen 5 3550H DDR4 16 GB RAM 256 GB PCle SSD Mini Computer, Dual-Band WLAN HDMI/DisplayPort/USB-C 4K@60Hz, 2.5G RJ45-LAN, 4X USB 3.0 ports). The programme worked, although it often lost connection to the router (via wi-fi). For this reason I tried to click on the button "reset to the latest firmware settings", but since then the programme no longer loaded, no longer let me enter via the GUI, and I was no longer able to reinstall it. I have tried all the latest versions, but it only goes as far as the 'Waiting for network connection' screen and does not go any further. There's just no way.
Can you help me? Can I try something else? Bear in mind that the mini pc is fully functional (both linux and windows see the network and wi-fi cards and can be installed on the pc itself).
Looking forward to your suggestions.
Alessandro
