Danley DTS-10 plans?
Are there any plans for the DTS-10 available? I've been wanting one for my home theater for a while but the kit is not available and I can't find any documentation. Has anyone "reverse engineered" the kit by measuring the pieces and where they go?
If my fears are confirmed, is there another design available that has similar performance?
Simply by scaling the pictures posted here and DSL's listed dimensions you could get "close enough for rock and roll".
Danley DTS-10 Tapped Horn Subwoofer
I did not peruse the site much, perhaps dimensions are posted. The design looks pretty straight forward, fairly easy to duplicate.
Josh Ricci's Data Bass site has a list of systems capable of 10 Hz output similar to the DTS10.
His Gjallerhorn output exceeds the DTS 10 at all but 10 Hz, but IIRC uses more power and occupies more space.
dimensions
Simply by scaling the pictures posted here and DSL's listed dimensions you could get "close enough for rock and roll".url=http://wardswebllc.com/Danley_DTS10/]Danley DTS-10 Tapped Horn Subwoofer[/url]I did not peruse the site much,
Josh Ricci's Data Bass site has a list of systems capable of 10 Hz output similar to the DTS10. His Gjallerhorn output exceeds the DTS 10 at all but 10 Hz, but IIRC uses more power and occupies more space.
Hi there Art: By request of TD in the AVS postings, due to potential patent infringement, internal dimensions were not posted. regards, Michael
