Dale CMF & RN Resistor
Need some advice regarding Dale CMF and RN. Are they basically the same wattage if we disregard the Mil-spec wattage derating for RN?
Let's say for use in amplifier, can we just equate:
CMF55 = RN55 = 0.5W?
CMF60 = RN60 = 1W?
Thanks guys.
~Kecap
Straight from the datasheet:
"Vishay Dale Model CMF is also available as Military Qualified Styles RN and RL. See appropriate catalog or web page for the MIL-SPEC ratings/attributes. (Except for marking, the Industrial and Military versions are exactly the same. Depending upon stock, military marked parts may be supplied as industrial rated parts)."
If I look at the RN datasheet, it says:
CMF55 = RN55 = 1/8W
CMF60 = RN60 = 1/4W
If I look at CMF datasheet, it says:
CMF55 = 1/2W
CMF60 = 1W
I think basically CMF55 = RN55 = 1/2W, and
CMF60 = RN60 = 1W
when not used in military equipment (Mil-spec watt derating). I'd like to know what others think. Thanks.
~Kecap
CMF55 = RN55 = 1/8W
CMF60 = RN60 = 1/4W
CMF55 = 1/2W
CMF60 = 1W
CMF60 = RN60 = 1W
~Kecap
I'd agree with that. For our use the specs are 1/2W and 1W. In mil apps the derating is used to make sure the equipment keeps on working in a middle east desert, all covered up with dust etc.
So it is strictly a derating, no difference in the resistors themselves.
Jan
