For Sale DACT CT-102 Power regulator, the included switching power supply is missing.
Things you have for sale.
The included 2 x 48V 250mA switching power supply were not found. Selling AS-IS. You can purchase any high quality switching power supply or use 4 x 12V battery to power your gear although I never use battery for these two sets before. Output can be set between 15V and 20V by selecting the onboard jumper position.
I used these 2 units to upgrade the analog power supply for my Mark Levinson 38 preamp and the result is stunning until the day I switched to tubes. These sets have been sitting in my drawer for years. I have a DACT CT-101 preamp for sale too. Please take a look if you are interested.
Key specifications / key features
(From DACT website)
  • Ready-assembled module, tested, ready for connecting to audio electronics circuits
  • Includes 100-250VAC mains adapter ready for connecting to the mains
  • Output voltage (customer selectable): +/-15VDC or +/-20VDC
  • Max. output current: 200mA
  • Peak output current: 10A min.
  • Output shortcircuit protected
  • Output impedance:
    0.001ohm at 1kHz
    0.002ohm at 20kHz
    0.006ohm at 100kHz
  • Output noise (IHF A): -126dB
  • PCB dimensions (L x W): 100mm x 90mm (3.54” x 3.94”)
  • Reduced capacitative coupling to the mains by
    using filtered switch mode mains adapter
These 2 sets have never been modified, you can observe that the motherboards were untouched.
Price is fixed including USPS shipping to the lower 48 states.
