I have a nice speaker, however I'd like it to have a better bass response. I was hoping I could get a relatively small receiver, to play the audio through the speaker and have a subwoofer working with it.
Any ideas?
Keeping cable count down to one, possibly two would be wicked.
Any ideas?
Cheap and effective bucket subs rock!
Check out Ed Schilling's FFRS Mark 4:20 Peerless 8" sub in a 5-gallon bucket. I just built four of them to add to my open baffle mains and they work surprisingly well. You should have a high-current Class D amp for the sub for best performance but for a quick and easy sub for under a hundred bucks each they're hard to beat. Tested pretty flat from 25-100hz!
All you need is a 5 gallon bucket and lid, some rubber feet, 25 lbs of concrete, a dozen 3" decking screws, 8 sheet metal screws, silicone caulk and a Peerless 830667 subwoofer ($66 each at Parts Express; free shipping if you buy two).
Build the FFRSMark 4:20i. plans/parts here!
Hope this helps!
I'll be posting a more detailed build report in the subwoofer forum within the next week or so in case you or anyone else is interested.
Regards, Jeff
Hope this helps!
Regards, Jeff
