Custom Experimental Box Design, Passive Radiator
here is what I am currently working on, any help is appreciated.
my box is currently SEALED chamber (4) for 4 12"s.
total box dimensions are as follows:
30" W X22.5" Deep at top, 25.5" deep at the Bottom
13" Height,
using 5/8" thick MDF already covered.
my internals are about 1cu ft per chamber SEALED.
front speakers I am using are Boston G5 12"s
when using the 12" Boston GTR radiator the box size stays at 1cu ft as with the sealed box design, so that being said,
I want to use the G3 12" recones as a passive radiator and add weights as an experiment to obtain a desired tuning frequency around 30hz, maybe higher.
coils have NOT been removed from the G3 recons (were still new) .
by using a quad sealed configuration for the box, I wish to "couple " the 2 sealed boxes together to make the G5 tune to the G3 recons in its enclosure. what size port to use to couple the 2 boxes together to get the desired frequency to make it all work together as a system. I can always add or remove weights if needed to help. all I want to know is what size hole (vent) to use inside the box for coupling 1 12 G3 Passive to the 1 G5 sub
ANY Ideas or thoughts might help, experienced people please add Ideas on this build!
<br>
<br>
