This topic applies to all audio applications. But I think it most likely to be of used with subwoofers.
The best theoretical loudspeaker book I've ever found:
High performance loudspeakers / Martin Colloms , 1991, is where I first learned of this idea. Colloms is convinced it will make for better sound.
Any thoughts, opinions, experience? Anyone built such? Anyone have a schematic? Any commerical products on the market?
A standard amp is a voltage source, and approximates zero ohms output impedance. A current source approximates infinite impedance.
With a high impedance source, the Qe of the driver disappears and the unit resonance is only damped by its Qm which Qt equals now.
High impedance idea may be a valid idea far above the main resonance. Its advantages as well as the restoration of the damping of the main resonance by motion feedback has been dealt by Hawksford :
http://www.essex.ac.uk/ese/research/audio_lab/malcolmspubdocs/C17 Current drive patent.pdf
and Greiner-Travis :
http://www.aes.org/e-lib/browse.cfm?elib=11756
Thank you. I'm reviewing your links now. I know this is complex, and I am aware of the damping issue.
Colloms seems to think it is good. Thats why I'm putting it out.
It came up in another thread as a way to run a subwoofer below fs. What do you think about it in that context?
Hi zenmasterbrian,
I have Colloms's book. He refers to Hawksford who says that current driven speakers exhibit lower distorsion. He shows some examples just as Greiner-Travis.
---It came up in another thread as a way to run a subwoofer below fs.---
Have you the reference ? I think of a misconception here.
forr, see Giant Subwoofer?
You have Colloms, fantastic. The idea of Current Source has been with me for a long time. Mostly from Colloms. It was only on this forum that I thought about it as being a good way, maybe, to go below fs.
There has been a lot of talk about current source amps on here, have a search. Quite a good discussion IIRC.
I may know the whole story about Colloms' idea about being convinced that current amplifier is the way to go, however I am confident that with his networking ability he knows many competent amplifier designers, I am confident that he could convince one of them to design one unit for him to test out.
Did this happen? I don't know. If it did what is the outcome.
Colloms just thought that it was one of the next boundaries to be crossed. He didn't say he was interested in doing it.
Any one find any threads about such?
Any one have any ideas about current amplifiers being good for going below fs
Time for something I have always been thinking every time this topic has been up for discussion.
What about headphones? Would they also have similar problems with being current driven, or could it be a more interesting option there?
If anything they would be more amenable to current drive since the headphone socket on 99% of amps is simply taken from the normal power output stage via a resistor of some 'significant' ohmage.
Nice module appearing on my website soon that can be used for current or voltage drive of headphones or line inputs 😀
Good point about headphones. Never thought about that.
Anyone seen other books that talk about current source amps? Anyone every seen or heard of such a thing? Has it every come up for analysis as a posibility?🙂
http://www.diyaudio.com/forums/showthread.php?threadid=3889&highlight=
http://www.firstwatt.com/articles.htm
http://sound.westhost.com/project56.htm
http://www.enjoythemusic.com/magazine/equipment/1204/firstwattf1.htm
http://www.enjoythemusic.com/magazine/equipment/0606/visation_nobox_bb_loudspeaker.htm
http://www.6moons.com/audioreviews/firstwatt/firstwatt3.html
http://www.6moons.com/audioreviews/firstwatt2/f2.html
possibly (don't speak/read german):
http://www.silbersand.com/
BM Universal Subwoofer (under the sitemap link)
zenmasterbrian said:ScottG, Lots of great stuff to read. I'm starting now.
You are welcome -
That first DIY thread is probably the best source of information on the interaction between amp and driver you will find anywhere. (..and largely due to the contribution of Thorsten.)
Mr. Pass fills in the information on crossovers nicely.
Rod Elliot shows important (but marginally usefull) information on op-amp methodes to obtain impeadance that you won't find elsewhere. Mr. Pass's F1 manual has a schematic which also aids a builder of these amps (though with discreet transistors instead).
The other articles are just to show subjective impressions and in particular the graphs DO has done to show the alteration in bass extension.
Combined - its a start.
Courrent source is not a good idea for a traditional loudspeaker (you' ll have a lot of problems with frequence linearity) but is veeeery good if you plan to use isodinamic speaker like magneplanar.
rinox, see that is what I'm wondering here. Tell me more about magneplanar.
See, maybe current source is or is not better. What made me bring it up here was discussions about running a driver below fs. So, its being run on both sides, and you want flat response.
Then, there is the damping issue. Maybe damping can be addressed with the enclosure?
I guess I'm saying, maybe current source has benefits, if its been worked into the whole design with the drivers and enclosures. Then there are also circuit issues of how to get the best current source.
I suspect damping ratio is defined differently in different situations. Probably if you drive current source, it is defined some how so that high Z works better.
If you drove matched, or mid level impedance, then you probably do have poor damping, but you could try to get it via the enclosure.
I'm not looking at matched, just current source. Likewise, crossovers have to be totally different for high Z.
But I'm only interested in multi-amping with active crossovers, so it is a non-issue.
If driver is connected to current source amp, such amp will give a correcting current for any induced by driver motion. So it is providing damping. Voltage source and current source are extreme cases. I think either provides high damping.
But there are other issues here. I'm looking at this for possibly going way below fs. That was how this came up. Can it be better there? That Elliot Sound might deal with this.
Besides First Watt, and Elliot Sound Products, is there any stuff on the market that works Current Source?
Any books that analyze it in depth?
Colloms mentions it only.
zenmasterbrian said:Besides First Watt, and Elliot Sound Products, is there any stuff on the market that works Current Source?
The only source I know of.. (you'll have to find the relevant topics for yourself):
http://www.essex.ac.uk/ese/research/audio_lab/malcolms_publications.html
- Subwoofers
- Current Source Amps
