Current Gain Calculations
Can somebody please confirm or correct me with the following:
Mad_K asked me about my AC current gain on my Aleph30. After reading through some relevant threads , I tried to measure my gain and came up with the following:
Applied 9V 1K sine wave, to 8ohm load.
Measured across R22-R27, 0.47ohm x 6, got: V=0.086
Measured across R37-39, 0.47ohm on neg. side, got: V=0.069 on each.
Thus: Iout=1.098A ..................(1)
I on neg. =0.44A total ............(2)
(2) is 40% of (1)
According to Mr.Pass, you must have about a 50% split or up to 60% for better bass.
Which way must this 60% be, 60% more to the output or 60% more to the neg. side?
In my case, is my 40% now good or bad? :scratch:
Thanx for all help.
(2) is 40% of (1)
Your calculation indicates that you are running about
60% gain on the current source, since 40% of the
output current is being provided by the negative output
devices.
50% provides generally optimum performance and efficiency,
although sonic differences are available by altering this up
or down. I do not advocate any particular value, so the
word "must" doesn't reflect my thinking.
I appoligise, must must be should, or must should be should. :spin:
If I understand correct, one can fit a 2K POT across R21, on Aleph30, and adjust to get closer to 50% - and then fit permanent resistor = this value. When I did this, I could not get my 40% up, only down. Must I now fit POT in series with R21 or is there another way?:
Make R21 next value higher in resistance,
and then try with 2K pot across again.
Keep on increasing R21 to the value at which you can adjust
to the 50% with 2k pot.
So it have to be over 50% with ONLY R21.
Because 2k pot in parallell can only lower the %,
and so adjust downto 50%.
This is only based on logic, not seen the schematic.
If it is too bad, so please correct me.
/halo
