Current capability of litz wire.
My back-of-the-envelope calculation says that the ( 342 strands of 0.05mm ) has a cross section area roughly equivalent to AWG 25 - which is only good for 2 to 3 amps in open air; less if it's bundled up or buried in a transformer winding.
Dale
"In Litz wire, with multiple levels of twisting very fine insulated wires, the amount of copper may be less than 30% of the total cross-section"
(from: Magnetics Design for Switching Power Supplies - Lloyd H. Dixon)
"None of the wire manufacturers gives very useful information on current density versus current capacity versus temperature rise versus wire size"
(from: Demystifying Switching Power Supplies - R. Mack)
Table 8-1 shows a sample of current capacity versus wire size versus current density. The temperature rise in Table 8-1 is for single layer coils. Temperature rise will be greater for multiple layer coils.
and yes, current densities in ATX psu is much higher than that, as AJT mentions; however there is also this fan; if this fan fails, life of this psu will be rather short ...
