CSS V series ML-TL with tweeter options
We are pleased to announce the CSS V series ML-TL speaker kits.
With the V series ML-TL there are 2 different tweeter options for those who would like to build the V series ML-TL.
The first option is the LD22C tweeter for those wanting to use the NEW soft dome low distortion tweeter from CSS.
Next option is the RT2 Ribbon tweeter for those wanting to use a ribbon tweeter .
More info to follow soon.
Here is all the cabinet information for those who have asked for the MLTL using the VWR drivers. You can start building your cabinets in anticipation of the kit releases.
Thanks to Jason for his fine artwork!!
Side view.
4 X 8 cut sheet
5 x 5 cut sheet
Cut parts list
Construction view
Front panel large driver cut outs NOT on baffle
Slot port cut out
Binding plate cut out OPTIONAL kit includes binding posts
Brace information
Baffle information LD22 tweeter
Baffle information RT2 ribbon tweeter
Just a little different views 😉
