CSS large kits coming
In the works a few more designs with the CSS wave guide plus this new driver
Side by side with the VWR and the new driver coming in some kits
rear view of both drivers
In the works right now are
MT large monitor ;0
MTM
MLT just to name a few.
UH205PW1
Monster driver
• Underhung voice coil• Linear frequency response• Ultra low distortion• FEA Optimized motor• Pressed paper cone • Vented pole piece• Dual shorting rings
• Precision machined undercut pole piece• Aerodynamic basket design• Acoustically transparent spider• Vented voice coil • Symmetrical lead wire placement• Gold plated terminals• Die cast aluminum basket
http://motusaudio.com/wp-content/uploads/2012/09/UH205PW1-Spec-Sheet-7-2012.pdf
On the wave guide Bob has them for sale but info I am not sure about.Look around the site.
What every someone uses for construction is up to them.If they want to use MDF go a head, if you want to use baltic birch or bamboo this option is up to who ever purchases a kit.Sure the same cabinet construction applies with any kit someone purchases from any company.
Al,
If it is OK with 1 1/4" MDF baffles and 1" walls, you could get away with 18mm baffles & 15mm walls if you used good plywood.
dave
😱😱 Started a few threads for ya
As these will be best to talk separately.The bookshelf monitor I designed the cabinets but Meniscus made them and we are waiting for them to arrive.
Once they arrive I will start on those as well.
