Crossovers active
Have focal es 165k speakers which came with 2 crossovers and memphis 400.4. Want to run all four on separate channels. Question is how do I wire. If I use 2 crossovers for the tweeters channels 1 and 2 where do I put the other four wires +, - for channels 3 and 4?
Each crossover has only one channel with tweeter and Woofer . Going to bridge amp, question is do I run front rca's from Hu to amp front only ? Set amp to 2 ch. Or do I need another set to rear on amp . In order to get stereo and the balance will work. One more on TA it gives me front and rear do I measure mid bass speakers for front and what do I put rears on 0 or what they assume I have rear speakers .
Hi, i think thread's title is: passive crossovers.
Yours OEM crossovers must have one input and two outputs.
Then, if you have the amp in bridged mode, there aren't issue, beacause we have two channel and two crossovers, so you can wire one crossover to each channel.
The outputs, to the speakers obviously.
Reactions: Haughtc
What a mess...
Might I suggest that you start from the start.
What equipment do you have ?
A simple list please. One item per line.
What are you trying to do ?
In simple terms please.
And a suggestion.
Might it be wiser for you to take the car to an audio installer, and let them install the system properly, to save you the risk of damaging things.
Lets go this way since I need a new amp .
Pioneer 4400 nex HU
RE 10" subs (2) 600 watt
Memphis 1500.1 at 1ohm
Focal es 165 k for the fronts
Had memphis viv 400.4 piece of **** 2 channels don't work whatever part of Question 1 also have focal coaxl in rear don't know if I should put those back in which is part of Question 2
Question 1 going to run just focals 165's up front what brand and channels do you suggest.
Question 2 if I use focal coaxl ( can't remember exact model) IF I put those in rear same question.
Mainly leaning towards running just fronts. Had ARC 400.2 loved it then went to the memphis 400.4 and rears and nothing but headache bridging, bi amping, band pass, active etc trying to keep it simple as possible but need amp brand and channels and size first
You have an amp with active crossover built in. You have a component set with passive crossovers. You haven't exactly stated that you want to ditch one and use the other. We'd at least like to be on the same page.
Keeping the current crossovers would certainly be easier, and it will also sound better unless you can do at least as well on your own crossover.
I'm not familiar with the amp, but the description suggests you have 24dB filters and presumably levels which is not a significant amount of control to work with.
