Crossover Questions/Suggestion
I finally build my first set of speakers. It is all house in a .50L enclosure.
The tweater is a Vifa D27TG-05(link) and the woofer is a Dayton 6.5" from PE(link)
Right now I had a Linkwitz Riley 2nd order crossover at 3khz. But the mid sounds kind of lacking. Yes I did reverse the polarity on one of the drivers due to the phase change. On the other hand I tried a first order crossover at around 2200 and it sounded better. Also for the tweeter I have a 2ohm resister in series with it after the XO to make it a 8ohm driver. (Am I doing this correctly?)
What do you guys think? A big thanks in advance
Woops.. sorry.. it is a .50 cu ft. enclosure, so it is around 14.5L. Has a 2inch diameter port and the length of it is 10 inches.
The mid sounds like it is not loud enough. I would say it is more in the male vocal range. Got to do some more critical listening tomorrow.
