crossover component positions
I'm not sure what your *-bump circuits are but if they are similar to L-pads then this might help.
I assume you're talking about passive crossovers.
Basically they are capacitors either in series or parallel with your speakers. The interaction between the impedance of the speaker and the capacitor causes it to as a filter which either passes highs or lows.
In the simplest case, say a single speaker. With an L-pad and with the impedance compensation circuits, it would be included as part of the speaker impedance.
So... the crossover is the whole thing. But you would want to connect your L-pad to the speaker and then treat the two terminals of that speaker+Lpad device as the speaker for putting your capacitor on to make the crossover.
Danny
