Crest 4000 amplifier info needed
Hi
Have a Crest 4000 amp, not the CC one, just the plain 'ol 4000. Been trying to find specs for it without luck. Even the folks at Crest say they don't have a thing, ZIp-zilch-nada. So, posting here in case by luck someone has the same amp or knows the specs or has a service or owners manual for one.
Thanks!
The amplifier doesn't know or care how MANY speakers you connect to it. All the amp ses is the total impedance of what you connect. In other words one 4 ohm speaker will be a greater burden on an amp channel than two 16 ohm speakers. And an 8 ohm cabinet can have one speaker or eight speakers in it, but the amp only sees the 8 ohms.
ANy amp has ratings, often printed on the rear panel. The amp will be rated down to some impedance - 4 ohms for example. A solid state amp like that will be happy with any load impedance down to that rated impedance. If it is rated for 4 ohms, don't offer it 2 ohms. Higher impedances are fine. An amp rated down to 4 ohms will be happy as a clam all day pushing 8 ohm speakers.
SO you have to look at the speakers you intend to use for their impedances. If they are 8 ohm speakers, then two of them makes 4 ohms. If they are 16 ohm speakers, then two of them makes 8 ohms. And if they are 4 ohm speakers, then a pair of them makes 2 ohms. Look at what speakers you have, determine what two of them would make and compare that to the amp rating.
