Crate PA-4 Distortion
I'm working on a Crate PA-4 with a distortion problem. I noticed that on some schematics I downloaded from this site it shows an opto isolator chip, OC1. My amp has no such part on the PA board. Any ideas?
Also, can someone validate that the voltage measurement chart is in fact somewhat accurate. I'm measuring about -8 volts at TP-4, the chart shows -1.78.
One last tid bit of info. The output shows a nice sine wave with no load and gets really nasty when I plug a load into the speaker. Any thoughts or coments?
Thanks Al
The voltage at TP-3 is about the same -8 volts.
And Nigel ... no, there is no relay anywhere. I did check the output transistors using the old meter way and they checked normal. However, I've been electronics long enough to know that sometimes even the most subtle deviation in component behavior can cause problems. So I took extra special care in checking the semiconductors I've check so far. If your somewhat suspicious that it could still be the output(s) because the nature of this amp I'm more than willing to go back and check again.
Thanks for all your responses.
Al
Schematic and layout attached
I just attached the schematic and component layout I've been working with. Notice the opto isolator circuit. My amp does not have this feature, whatever it is. Does anyone know what it's for? And on that note does any one have schematics and layout for the amp version without the opto isolator?
Thanks Again
al
