I have a friend that is looking for a schematic for the Counterpoint SA-7 preamp. He has a unit that is in parts and he wants to upgrade it. Any help on this?
Unfortunately I have copies of some other Counterpoint preamp schematics but not the SA-7.
If no one can help you out you could always ask Michael Elliot.
He's the brain behind the Counterpoint gear and is still supporting most of what was previously produced:
ALTAVISTAAUDIO
Cheers,😉
ALTAVISTAAUDIO
Cheers,😉
Thanks for the Alta Vista Audio link. I wondered what happened to Counterpoint. Their products seemed to me well built, with decent execution etc. Then they vanished. Could it be but, ah, yes, their bank, of course, got nervous, and pulled the plug.
Mr. Elliiot is a very nice and unselfish man.
I hope that his Alta Vista entrerprise is going swimmingly.
Oh yes, those were fine products indeed.
My first commercial preamp was a SA-5. Michael Elliot was one of the first to use automatic bias in preamps, gridleak bias on the less expensive models as well.
If ever any of you come across a dirt cheap second hand SA-11 preamp, give me a ring....
My own top of the line preamp was inspired by that model but I didn't quite dare to push it that far though.
Cheers, 😉
Cheers, 😉
Oh, my, I remember wanting an SA-11 many years ago as a graduate student, but my budget allowed only for a used c-j PV-5. Mr. Elliot certainly was ahead of his time.
a bit steep
A bit of an understatement. I wonder why this site is so popular - the upgrades and all services seem to offer dismal value for money.
Send me a PM for the SA7 circuit. I once used to have it and still keep a reasonably detailed circuit (took me no more than an hour of staring at the board to draw it). No PSU as it looked like a textbook emitter follower.
Don't like the price?
Quote:
At $75+shipping, the manuals are a bit steep. BTW anyone got a schematic for the SA-3000 TIA.
Gentlemen.... The price may seem a little high but when you stop to consider the time and energy involved in designing/building the units its a bargan in my humble opinion. You could always get out Mr. Longhand and draw the darn thing yourself.😀
Joe
Joe
Flawed circuits
Hi all,
At the risk of starting a fire storm, I'll make a comment here.
I was authorized warranty for Counterpoint right to the end. There are many basic circuit flaws in his designs, power supplies seem to be the worst. The SA-9 is just waiting to blow.
His equipment did sound very good preamp wise. There were some really good concepts in design.
Having said that, if you pay attention to decent parts, upgrade the wattage on the plate resistors if they are discolouring you will be fine. Get some decent tubes in and listen to it before going further.
I am in the process of redesigning the SA-100, and have one sounding great. This is still evolving. You should have seen the serious design errors in that thing.
As far as the charge for schematics / manuals go. They are grossly over priced. They have always been way over the top for pricing. Oh yeah, he really did match the output fets incredibly tightly. He had no choice with no source resistors!
analog_sa, that's one I don't have. I agree totally with you on "the upgrades and all services seem to offer dismal value for money." comment.
-Chris
Hi all,
-Chris
Counterpoint schematic
If anyone has a schematic for an SA-3 or SA-5.1 preamp, I would VERY much appreciate a copy emailed to me at WarJarrett@aol, thanks in advance. --Warren
Back when I was in retail we had Counterpoint for a period. Pathetic gear. Setting aside sound quality, there's no denying that the stuff was junk, design-wise.
We had an SA-3 (single spaced rack mount preamp, yes? I think I've got the model right). A resistor got so hot that it burned the paint right off the lid of the chassis. (From memory, I think it was a 5W resistor running at around 4.8 or 4.9W Pd.) Called Counterpoint to express concern. The guy insisted vehemently that the part was within spec and that it was normal for it to run "warm." When we noted that burning the paint off the top was more than warm, the guy got really, really angry and started yelling. Hung up on us.
Needless to say, we dropped the brand like a hot potato.
I was sooo not surprised when they folded.
Grey
Grey
There were at least 2 versions of the SA7. I think the earlier type had a very shallow chassis with the tubes all on a pcb mounted behind the front panel while the later type used a bigger chassis with the line stage mounted across the back panel and the phono stage along the LH side.
They were quite well made and sound ok but I have to agree with the comments on Altavista pricing.
Hi Grey,
That had to be Michael! 😀 His idea of parts running within spec was such a joke! As you noted, he hasn't a clue what derating is. Mind you, I understand someone else did the very earliest designs. This does sound like M.E., he hasn't changed much. BTW, he designs by ear. He even admitted that.
Hi stoolpigeon,
-Chris
Hi stoolpigeon,
They were both the same physically. He changed tubes and added an auto mute. The earlier one was completely manual I believe. Could be wrong here, but that is what I recall.There were at least 2 versions of the SA7.
-Chris
I don't have them handy, but yes, the one in the bigger case has an auto mute.
Also, I think on his site he mentions a version with an output fet but I haven't seen this one.
Hi stoolpigeon,
He used a BUF03 in many of his SA-2000 and higher preamps. He also used it for the output buffer of his phono section.
Great idea, poorly executed. Now he pulls them (and keeps them) to remove the solid state sound. I bet he has some BUF03 line stages now.
-Chris
-Chris
I just checked the web site and the buffer is mentioned as a prior upgrade. Charging to put it in and then charging to take it out - nice work if you can get it!
Just for giggles, I hit the Alta Vista link above. He wants to charge you $100 to make sure your Counterpoint doesn't run hot.
Gee...I can't imagine why anything made by Counterpoint would run hot.
Most of the Counterpoint gear looked nice, I'll say that for it, but if someone were to walk up and give me a piece of their gear today, the first thing I'd do would be to gut it and build something else into the chassis. It's a shame, really, as there aren't that many brands I'd treat that way.
Grey
Grey
Despite my negative remarks I like the SA7 and as a budget model I think the designer did a good job. SA7 was always a favourite of Ken Kessler, one of the few journalists I used to read. Is he still about?
- Tubes / Valves
- Counterpoint SA-7 Schematic
