Seismic Audio has a bass guitar cab with a frquency range of 40hz to 16000hz. I am interested in using a cab for bass as well as guitar. What would be the considerations? I have heard of many guitars using bass amps/cabs regularly, especially Bassman amps.
You can safely use a bass speaker for guitar. The reverse isn't true: bass guitar will make a guitar speaker flap around, causing mechanical damage at higher volumes.
You might find there's too much high treble for distorted guitar use: most guitar speakers stop before 5kHz.
Thanks Chris. So a bass cabinet with a lower high frequency peak may be more desirable for guitar?
The old Bassman amps had 10" speakers, which is why they worked well for guitar.
If you're using a tube amp and distorting it, then you definitely want to use a guitar speaker. The reason Greenbacks and V30s are two of the most popular guitar speakers is because of the way they filter the tube's distortion.
If you're using a modeling amp with cab simulations, then the extra high end of a bass cab's tweeter would be useful. Even so, few bass cabs are actually flat, which is what you'd want for a modeler.
That said, you won't hurt anything (except your ears 😉) if you play guitar through a bass cab, and if you play clean, you might like it.
I reckon it would work
personally I like a more 'mellow' tone for bass
or you might say, less peaked midrange
and peaked mids is exactly what many want for guitar sound
in other words, my personal sound preference for bass might not work very well for guitar
unless you fancy big and mellow tone for guitar 😀
could work well with blues music and jazz
other people could say the exact opposite
why 😕
I am trying to avoid having multiple rigs as I play bass, electric and acoustic guitars. I play worship music most often direct through the pa with my pedalboard. But I do need a rig for when I play outdoor shows, coffee houses, etc. I don't have the storage space for two or three rigs.
Would it make more sense to get a 4x10 cab with a freq range of 45hz to 5khz?
Is the Bassman Reissue still reguarded as a decent bass amp? I know they have changed the classification as its typically used for guitar these days.
one simple guitar cab, for guitar
and adding exstra woofer cab, maybe with built-in power amp, whenever needed
it gives you more and better options, for whatever job you have
You can probably get better for bass guitar: the speakers are in an open-back enclosure, so you won't get much in the way of low end out of it.
I use a sealed 4x10 cabinet and a 300w Laney amp for both guitar and bass. One of the speakers is a dual-cone one that extends out to ~15kHz, making it usable as a half-decent PA system.
Its great for band practice as I put the mixing desk in the fx loop and then iPod, mics, even electric drum kits into the mixer.
Chris
Chris's solution sounds good, or for portability, two 10s and a tweeter.
This assumes you don't need a guitar speaker if you can get a good sound going direct, and that you'll be mic'd outdoors.
...... two 10s and a tweeter.
then I would suggest two 10s, and yet another 10" for the 'tweeter job'....and the upper 10, you can make that one open back, if you wish 😀
Or maybe a 6", like the Eminence Alpha 6A.then I would suggest two 10s, and yet another 10" for the 'tweeter job'....
Good idea, especially for the acoustic guitar..... and the upper 10, you can make that one open back, if you wish 😀
- Live Sound
- Instruments and Amps
- Could the SA-310 bass cab be used for a bass and guitar cab?
