Hi there
I am new to this site and am amazed by the amount of information and activity here. I was wondering whether anyone can tell me how much it costs approx to build the Zen amp currently listed in the passlabs diy page?
I am sure this was discussed before but I did not get any figures when I did a search. I did get figures such as US $500 to $700 for the Aleph 4 DIY.
Also, for someone who has no experience dealing with circuits (except basic soldering) how hard would it be to build this amp with the given instructions and material?
thanks so much in advance
vsr
vsr
Have you read Nelson Pass' article on the Zen and its variations? If not, go to www.passdiy.com and read them, they're very interesting. From the articles you will find out every part you need. To price all the parts go to www.digikey.com. For transformers try www.plitron.com. Hope this helps!
hang on, lemme help.
i just priced all the parts i could find on digikey, so i'll write them all down tonight. wait a few hours.
/andrew
...unless you want to just go ahead and do it yourself. it's a hassle, but it doesn't take long.
/andrew
i started here with just a very very very basic knowledge of how to solder, and my first project was an aleph2. (still in progress actually). ive learned a lot, but i still have a great deal to go. dont let that hold you back, there are great ppl here that are willing to help out.
Joined 2002
to build a zen4 it would cost you about 400 canadian that is soo cheap fora 25watt class a amp. Nelson does some realy nice stuff. I WOULD LOVE to have some thing that he manufactured.
following are minimum quantities for 2 channels of zen amp (v4) goodness:
priced in US dollars
Q1,Q2,Q5.....(10) = 18.00
Q3.....(2) = 0.96
Q4.....(2) = 1.98
D1.....(10) = 0.40
Z1-Z5.....(10) = 1.65
C1.....(2) = 10.02
C2,C4.....(4) = 18.32
C3.....(10) = 1.80
C5,C6,C7,C9,C11.....'obsolete' on digikey
C8,C10.....(4) = 1.20
C12.....(4) = 1.20
R0,R14,R15.....(10) = 4.88
R1.....(5) = 2.44
R2,R5.....(5) = 0.54
R3.....(5) = 0.54
R4.....(2) = 2.58
R6,R11,R12,R16,R17,R18.....(15) = 1.62
R7,R8.....(5) = 0.54
R9.....(5) = 0.54
R10.....(5) = 2.44
R13.....(5) = 0.54
R19.....(5) = 0.54
R20.....(5) = 2.44
total for components = ~$76 + cost of those caps not found on digikey
heatsink - varies. the cheapest one i've seen on the web so far is probably the 24 incher at MECI for 30 bucks. you'd need 2 of those i guess...i'm not sure what the °C/W rating of that one is. you need one rated .3°C/W max.
transformer - haven't priced yet.
chassis - haven't priced that either - although the wood ones in the gallery at passdiy are probably pretty cheap to make.
pcb's - get 'em for $50 for a pair at pass, or get a friend to make some from the gerber files, or find a good deal at an online pcb manufacturer. (such as advanced circuits, where i got mine made. 😱 )
misc. expenses will include connectors, wire, power cord, maybe a cool meter or something, a neat power switch, and a BLUE LED IS ABSOLUTELY REQUIRED.
hope this helps!
/andrew - is formulating his plan for the Ultimate Frugalphile Penultimate Zen Amplifier!
Q3.....(2) = 0.96
Q4.....(2) = 1.98
D1.....(10) = 0.40
C1.....(2) = 10.02
C3.....(10) = 1.80
C12.....(4) = 1.20
R1.....(5) = 2.44
R3.....(5) = 0.54
R4.....(2) = 2.58
R9.....(5) = 0.54
R10.....(5) = 2.44
R13.....(5) = 0.54
R19.....(5) = 0.54
R20.....(5) = 2.44
hope this helps!
PCBs
Why you are not using p2p connections?
You can save $50, and it is sound good too...
BR,
Milan
BR,
Milan
Cost of V4 Zen
I ended up with around 400.00 US in my Zen V4. I suspect you can build it a little cheaper. I spent three weekends on the chassis, but my family only gives short windows to do such.
The heatsinks are the toughest, lucked up on some at Tanners in Dallas. Went back two months later and someone had cleaned them out.
Also, be prepared to wait six weeks for the Plitron power transformers. They build them on order.
George
George
I'm building a pair of Zen V4 tube version. The design is a variation of NP's Zen V4 with a Tube instead of the ZVP.
At the moment the meter stopped at 350 euro.
I still need connectors and and thick piece of front material for the front of the cabinet. I've allready bought a bunch of blue leds though
i'd like to hear how the tube substitution turns out. i didn't see any info on your site about the tube scheme - what else are you modifying to accomplish this feat? could be a good project for a newbie like me...
/andrew - might consider an Ultimate Frugalphile Penultimate Zen TUBE Amp...😎
You can get transformers from apexjr for $9.99. (48VCT 7A use half of the winding). I used a pair for my original zens. He also has some caps (10000uF 50V) for $1.50 each. The web address is http://www.apexjr.com I think it can be done for $50 per channel if you go really cheap on transformers, caps and heatsinks. If you really want PCB's try Olimex.
Darrell Harmon
Darrell Harmon
Thanks folks!
To everyone who responded to my post....thanks so much! This is really a great forum....I hope to get started on something soon and I can bug you guys even more!
cheers
vsr
cheers
vsr
Newcomer
I am very happy that I found this forum. I have spent a lot of time reading many messages here. The stuff that is going on is quite impressive!
I have a desire to build a son of zen amp and a BoSoZ to match (mate?) with it. In Mr. Pass' article on the BoSoZ he gives a very nice listing of the components that he used with the Digikey part numbers. Does anyone know of a concise list of very high quality components with specs and for the SoZ? (and perhaps part numbers??
) If such a list exists I would greatly appreciate it if someone could point me to it.
Thank you very much.
Vic
Vic
Re: PCBs
I think every ZenV4 builder should buy PassLabs PCB to reward Nelson for his support to the community.
mpopovics said:Why you are not using p2p connections?
BR,
Milan
- Cost of the Zen pass labs amp
