Cooling fan in my LM3886 stereo amp
Hi again,
I have built a Gainclone based on this schematic: http://diyaudioprojects.com/Chip/LM3886_CA/LM3886_CA.htm
The heatsinks get quite hot, and I was thinking about putting a fan on the inside that sucks air out, and drill holes around the chips, so that most of the air is sucked in from that area.
But how can I design the fan circuit? I thought about having 9 to 12 V on the fan, and I tried to put a 220k in series with a 470k, parallell to the +32V. But I guess the fan acts like an inductor, because when I put the fan across the 220k, the voltage across the resistor fell to 1V and the fan did not work.
Does anyone have any ideas to how I can get it to work?
do not run the fan off an audio PSU.
Supply it from a separate PSU, either from a separate winding off the transformer or from a separate transformer.
Select the Vac to suit the fan motor.
Arrange for some kind of temperature control. Off when cold. Medium speed when warm and fast +warning light when hot.
Be careful to ensure it starts when on medium speed.
It might need a kick to overcome friction and then slow to medium speed.
I would also fit a high temp mains switch to the sink in case of failure of the fan/control circuit.
I have run a fan off the main amp PSU with just a resistor to slow it down and there was no audio noise. I have also done it with lots of audio noise. For no noise it requires maybe some shielding and good PSU PCB design. I had to shield the input wires and the fan wires. You can also get a 12V fixed regulator to run off the main PSU lines. This helps with isolation of the electrical noise on the PSU lines. The best option is to not use a fan at all.
-SL
