Hello,
Please suggest whether I made a mistake replacing the TORX of my digital source/tv box/ with a coax inlet just taking out the TORX and installing a BNC receptacle on it's place soldering the ground and the central pin to the TORX point points.
Thanks in advance,
Ignat
Thanks in advance,
Ignat
TORX outputs clean digital signal with TTL-level values. Coax is basically sine waveform at hundreds of mV S/PDIF - Wikipedia
Conditioning the signal e.g. epanorama.net/S/PDIF Interface
TORX outputs clean digital signal with TTL-level values. Coax is basically sine waveform at hundreds of mV S/PDIF - Wikipedia/QUOTE]
Thanks for your reply but since my DAC accepts only coax I have to try best coax connections, that is the problem.
