My friend bought Pass Labs XA60.5 when he had been in USA. So it's voltage setting is 120V.
Now he is in Korea and using it with voltage converter.
But he hopes to use it without voltage converter.
Is it possible to convert PL XA60.5 from 120V to 220V?
Any advice or document such as service manual would be helpful.
I suggest that your friend contact Pass Labs directly with the model and serial numbers of his amps and ask for advice. (try email: service AT passlabs DOT com)
An interesting option would be to use either of these two larger external transformers and change its transformer taps to primary windings in series, which from the spec sheet looks easily doable. Costs ~$200 and still an external solution, but should yield nice results. Would also provide extra outlets for other 120V devices that are small signal/low power.
https://www.antekinc.com/balance-power-supply/
