Converting Forte Model 3 to Model 1a
I believe I saw a post by Nelson some time ago that all that is required to convert a Model 3 to a Model 1a is to change the power supply ground plane and increase the bias. Is this correct and can someone help me with a schematic or other docs? I own both amps and want to convert the Model 3 to a Model 1a to use in a vertical biamp setup.
