I'm using Autodesk Fusion 360, but exporting as DWG or DXF format is greyed out.
Using instructions to export as DXF, I did create a file with the object's outside dimensions, but the surfaces were blank and devoid of any details.
Currently, the application can export .f3d, 3mf, fbx, obj, skp (Sketchup files), smt, STEP, STL and USD. 😒
Is there a conversion tool that can accomplish this?
What are you trying to export?
You do know that dwg and DXF are 2D, therefore only x and y coordinates will be included.
Hi
Export from a Fusion 2d drawing to dxf/dwg, you need to pay for the better version.
But if enough for you, and Ok given the part you design, you can do it from the Sketch. From there, dxf export is possible/free
Did that for a plastic sheet to be cut and bent
A faceplate to be cut on a 3-axis milling machine. There are constant angle chamfers around holes on the face. The angles should be captured in 2D, but if it requires special details please correct me.What are you trying to export?
Looking at the Z-axis the holes are larger circles in the top layer and smaller on the bottom layer. Viewing the X and Y-axis should show the angle.
