Sir,
I have made Clone PCB for your First Watt Amplifiers..
I have not heard on this from you.
NP request your consent .
Here is link to Clone PCB based on your work..
http://www.4shared.com/file/109435333/d8b8554/AMP-FW-F3-SA.html
http://www.4shared.com/file/109435411/d4fc907f/FirstWatt-F5-SA.html
http://www.4shared.com/file/110546244/ef970911/FirstWatt-PSU_Boards2.html
http://www.4shared.com/file/109435407/2484040b/FW-F1-AMP-SA.html
suds
suds
Good Board's, less price.
Making boards according modifications suggested by members here. (Like change component size, type). intention to provide quality boards, on cost sharing, benefit for me, I get to learn, and get my proto boards covered.
Also some DIY'ers from India are not able to buy board's cause of cost, and shipping would like to make board available locally.
Thinking of !! I have left over boards initial one with IP issue, one I made copy of F1 (I did not know about IP issues then) 5 Nos F1 Amplifier Board will gave away free, only shipping cost applies
and next lot with changed layout Around $19 a Set (2Amps, 1 PSU) and $1 per set to DIY
F3, F5 they would be new boards.. will keep at $25 per set initialy (due to Setup, NRC Charges) then drop the price accordingly.. (same $1 Per set to DIY)
does it sound ok ?
What specifically are you offering?
A free sample?
does it sound ok ?
Nice 🙂
Sorry! I don't want to be part of issues anymore so!
ok I will post for Give away and GB ..
Also, for Indian DIY'ers is it appropriate to post GB in hifivision and other forum ? any restrictions ?
suds
suds
suds said:5 Nos F1 Amplifier Board will gave away free, only shipping cost applies
I meant a free sample for Nelson as a bribe 🙂
You meant as a tribute😉
Not sure but I think the OP is asking to attach NP name to his PCB design for sales (Group Buy?)
I had done a mistake may be unknowingly, this is fair chance to pay for it in way I can afford to !
OP ?? I am not familiar with most names here !!
all new work has it, Original Copyright by Nelson Pass on all boards, as NP stated this before, like Board should have DIY, etc.. !
I prefer that you leave the NP off. If it is your artwork, then you have the copyright.
I put it as Original Copyright , not Original and Copyright ! 🙂
If something wrong with your PCBs . . . Saying "if" . . . Even if the users make mistakes and things wrong . . . All blame or claime might come back to NP . . . So, you need to protect Papa by removing NP off . . . IMHO . . .
But its clear that , original copyright is NP, and PCB is clone not original. I will make modification to next issue, and these are almost ready.
It's clear to you and to me . . .
However, the users could easily misunderstand that the boards are made by NP . . . This is the trick and why the copycats like to put his name on in a way or another . . . The meaning to be clear to the users not to you . . . Don't you think so?
- Consent for work on your FW
