Connecting a Denon 2803 & 3803?
I think it would be possible to run the 3803 as a main amp and use the 5.1 pre-outs through the 5.1 input (ext. in) on the 2803 running it Direct. Connect all your speakers bi-amped with highs on the 2803 and lows on the 3803 and adjust the volume on the 2803 to the right level and after that use on only the volume control on the 3803. Obviously you need speakers that are bi-ampable.
