Comparing these 17" Projector design
Projection lens FL = 500mm
#1
Condensor Fresnel :220mm
Field Fresnel: 650mm
#2
Condensor Fresnel :330mm
Field Fresnel: 330mm
What's pro/cons different of those setup? How does the diameter of projection lens would make different if they are the same focal length? (Says 10cm and 13.5cm).
Thanks for any comment.
