Commerical Projector Lamp modification
Hello,
I have an Infocus LP425 DLP projector with a blown out bulb. It takes a 270W metal halide bulb and is rated at 500 lumens or so. It is possible to modifiy it to use a cheap 400W halogen like they used in their early projectors like a LP550? I know they are only rated at 150 lumens or so but since I never use it during the day I thought it might be doable. I have no idea if this would work but I thought I would ask anyway. Thanks.
Ebay have alot of infocus lamps all the time im sure u can find one easy for cheap. Try searching every possible way like part #, model #, and cross references if you know them. It will be worth your time if you can find one for less than retail.
