does anyone know how to do this?
understand that no electronic conversion is require for DVI t o HDMI, just re-wiring. But does anyone know how to wire/convert the SPDIF output into HDMI output?
You can't just make a cable or passive adapter. Audio is sent on the same physical data lines that are used to send video.
DVI has to be decoded down to RGB/YUV and re-encoded as HDMI with the audio stream inserted. Plus, I'm not sure how audio clocking works over HDMI but you may need to do ASRC also.
In other news, buy a box.
