This may be the dumbest question for you guys but here goes.
Can a lead wire connecting to the inner terminal of a air core foil inductor pass through the coil center?
I'm mounting the coil flat to a board and would like to run a wire up through the center through a hole in the board. The examples I've looked at have the wire crossing the top of the inductor, but I've not seen any through the center. And I can't find any comments that it would be detrimental to the sound.
An example, not like you guys have never seen one 🙄
No problem passing the connecting wire for the inner terminal through the hole in the center.
BUT: if you mount the coil flat on a copper-clad board, there will be a bit of stray capacitance between every turn of the coil and the copper board. That will have an effect at very high (radio) frequencies.
