I'm contemplating building a 12AE6A based Millet Hybrid MiniMax Preamp found here:
MAX Schematic
It would be built as a monoblock, however.
I have a nice 50/60hz power transformer with 115v Primaries and 10v secondaries @ 2A and It's center tapped. It would be great to be able to use it 🙂
I ran this Cockroft-Walton full wave voltage multiplier in the Falstad simulator and it runs very nicely at ~26.18vdc average, with no load. My computer won't handle the full schematic in the simulator.
Cockroft-Walton full wave voltage multiplier (please excuse the drawing):
0 | Transformer: 50/60hz 115vac primaries 10-0-10vac seconda… | Flickr
I have some LM317T voltage regulators that can be used.
How feasable would this power supply be for the preamp?
Thank you in advance.
MAX Schematic
Hi Gypsy,
If it may be useful I recentely built a more minimal hybrid schematic going through a voltage doubler for B+ and it worked nicely.
I'd recommend to use a two capacitors of 470uF at least (1000uF are better) for the doubling part, as to have no problem with ripple and too low current output. I needed only few mA, but I think it's possible to get easily up to some dozen mA, if the transformer supports al least 4-5x the current demand.
Hey Indaco,
Thank you for your reply. I actually have some 470uf 35v Capacitors that should work 😉 I removed C7, C8, C9, C10, C11, C12and R2 from the Schematic and increased the Capacitors to 470uf. It runs much better in the simulator now. I put a 2.2uf filter capacitor in line on the dc output. I'm gatting an average of 28.20vdc with no load. I think it should run very well with the LM317 regulator. I don't mind a little 50/60hz noise, it just adds to the charm of a tube based device IMO.
Hi Gypsy,
I would love to see the schematic you used, if possible 🙂
