lots of name are used!!
I will called this "storm clock"
this is the dds clock.
can be output the wordsync,bitsync.
it is programmerble once the frequency is choose.
the frequency can store in the onboard memory.
also communication line between special battery board is avaliable.
support frequency🙁WS)32,44.1,48,88.2,96,176.4,192Khz
bit sync:4.2336,11,2896,12.288,16.9344,18.432,22.5792,24.576,33.8688,36.864Mhz
should be sync with all CD and DAC......
debug nearly completeD!
He talks about DDS. I googled to find "Direct Digital Synthesis".
It seems like it's a clock synthesizer. Wasn't it in "The 'best' performing clock" topic that someone talked about that?
http://www.hit.bme.hu/people/papay/sci/DDS/start.htm
Re: Storm Clock?
I call it "a storm in a tea-cup" clock. Way too many parts.🙄 What was the name again?legoman said:lots of name are used!!
Re: Re: Storm Clock?
Hi Elso
there is too many name like"super clock,ultra clock....etc"
so I called my clock..storm-clock.storm is my son's name.haha
why it's manymany parts?
because it can use with my battery supply 1543
Hi Elso
Re: Re: Re: Storm Clock?
I hate batteries, they are always empty in weekend, when shops are closed, or when you need them.
What counts is a low-noise supply suitable to power a RF circuit....
A good design has minimal parts count, yet optimal performance. DO YOU HEAR ME PER-ANDERS? (and Lars Clausen too, LOL)
I hope your son is not as stormy as his name, no offence meant!
Battery supply?legoman said:
Hi Elso
Re: Re: Re: Re: Storm Clock?
haha!
most of battery powered audio equipments have a lots of problem.
I use rechargeble!
so,I make the battery controller to make this easier.
watch it here http://storm-digital.com/diy/eng/psu1e.htm
Elso Kwak said:
Battery supply?
haha!
I use rechargeble!
Re: Re: Re: Re: Re: Storm Clock?
Still can be empty when you do need it! 🙄
legoman said:
haha!
I use rechargeble!
Re: Re: Re: Re: Re: Re: Storm Clock?
......ho
1./when the battery empty,it will switch to charge mode automatically.
2./I has the power supply back-up when the battery is empty.
3./don't think the battery supply need to disconnect from the wall socket everytime.the control circuit needs to use AC power..
hohoho
......ho
hohoho
So.....is it really DDS, or not........?
If so:
Hope you don't expect it to be quiet........even if it doesn't use battery power. Or have good spectral purity.........
Oh, what's the use.........go ahead build the damn thing. Don't expect the world to beat a path to your door.
Jocko
If so:
Jocko
- Digital Source
- CLOCK Module
