I have a crate Gx-65w guitar amp.I have replaced the cooked o/p transistors but the amp clips at low volume reguardless of which channel is selected.A C.R.O shows the o/p of I.C.3(an NE5532p) forming a square wave when the gain pot is only moderately cranked. Ihave checked most components and found no reason for this behavior.Any ideas would be great.Thanks
Very unusual... Check transistors Q10 & Q11 for short circuit C-E (these are the overcurrent shunts) and R73 & R74 .33ohm 5W resistors for open circuit.
With no signal, there should be 10mV DC across R74 - this can be adjusted with trimmer AP1.
Unusual circuit.
Cheers
Unusual circuit.
Cheers
