Class D step-up possible?
I want to step up the output voltage of a class D amp. Did some searches and didn't like the answers 😕 that said the output transformer needs to pass the lowest audio frequency. Can somebody explain this in more detail? If the output transformer passes a suitable HF PWM signal it seems possible. No doubt I'm missing something- never worked with class D. I thought isolation amps that want down to DC used a method like this. Been wrong before though.
Thanks,
CH
I'll admit I'm a complete idiot with severe comprehension problems, but I feel like taking a guess at this one.
Is it that the inductor would have to be large enough to pass the lowest audio frequencies, which in turns means the inductance would be unsuitably high?
The PWM signal contains all the audio frequencies plus the carrier HF. Feeding the unfiltered PWM signal to a big transformer is not a good idea due to possible EMI (leakage inductance would do the output inductor job).
The transformer needs a big enough core and a high enough amount of primary turns to prevent saturation at low frequencies. Exactly as every other audio step up/down transformer.
I know someone who used multiple floating class-d amps connected in series in order to achieve voltages up to 1000 Volts (to drive a piezo actuator) with success. The disadvantage is the complexity that already starts at the PSU level (multiple foting supply voltages).
Charles
