Class D electrostatic direct drive
As an owner of direct drive electrostatic speakers/amps as well as Hypex NCore amps which I think are pretty great, I'm curious whether Class D would be a good choice if one wanted to develop an amplifier to directly drive an electrostatic speaker panel at around 5000v. I'm interested in developing/experimenting with contemporary direct drive amps for electrostatic panels.
If you switch at low voltage and step up with a HV trafo I don't see why that can't work. Who says you can't switch HV just because it is HV? Sure, you may not want to do it because of the massive EMI and RFI emission but that is different than it can't be done. Nano second switch speeds are achievable at kV levels with special circuits like thyratrons, spark gaps, massive series transistor banks etc. for lasers all the time.
Yes not quite the 5000v that my Acoustat servos deliver. I'm not an expert enough to know how one would design in order to increase the voltage -- perhaps a series of gain stages. The Acoustats use a voltage doubler which is a fairly simple thing to implement if you know what you're doing.
