Class D 10W kit?
Considering you can get TPA3118 ready-populated amp boards for under 2$ (that's TWO DOLLARS) delivered, and depending on the supply, they can put out up to 40-50W...
Well, "you do the math" 😀
In translation - you won't find anything like that. And with prices like that, even if you did, it really wouldn't be worth it 🙂
Or, if you really insist on some kits you want to assemble (ie. solder together) yourself, class-D amps might not be the best place to look / start, imho.
