I'm looking for plans including PCB artwork for a quality class A power amplifier, past or present.
I saw the Pass A40 and have put that in the box but was wondering if I can get get any other leads?
40 - 100 watts is fine for my application, I'm not looking for anything that requires a forklift.
I'm also curious about any popular used class a power amps that can be recommended....I've seen a few....but not sure if they're truly class a.
Did I see an old NAD that was? I 've seen Yamaha and a few others but wonder if they're truly class a.
THANKS
THANKS
Try having a look at the pass aleph-x, it should be able to give you the sort of output power you want quite easily, and there has just been a large order placed for PCB's for the design, whihch you should be able to pick up for yourself if your quick.
