Hello guys,
I'm trying to find a good article to understand how a A\B switches from each class. And I can't find anything the explains it completely. Does anyone know of a good article?
I have a X3 in the way. I read that it switches from A @15watts to B. I would like to know what that means. I'm not sure if it means if my speakers are 90db sensitive. At 8 watts I can get to 99db and still be at class A?
Thank you guys I really appreciate it a lot.
So I can keep it in class A as long as I'm under 15watts correct? So at 90db sensitivity. I can reach 99db @8watts and stay in class A?
you know , if Papa became deaf enough to not hear da Klunk! in amp properly made , I'm pretty sure that you and Mighty Moi are having at least 6 deaf ears , together
There is no switch. The circuit of a Class A amp and Class A/B amp can be identical except for the amount of bias. Lots of bias means that the amp must be physically big with a huge PSU, and large, very warm (read hot) heatsinks. This is expensive and inefficient, and is why most amps are not Class-A.
In theory, with your 90db speakers at 1M distance the SPL should be;
1W = 90db
2W = 93db
4W = 96db
8W = 99db
16W = 102db
32W = 105db
64W = 108db
128W = 111db
256W = 114db (yes, I know your amp doesn't have 250W)
So yes. There will be no klunk at 99db. 😀 😀 😀
But much, much, much more important than the mythical klunk (which doesn't exist🙂 ) is by this computation, you have 10db headroom above your 99db target before the amp clips.
8W into 8r0 requires an output current of 1.414Apk and an output voltage of 11.3Vpk...................... At 8 watts I can get to 99db and still be at class A?..............
To remain in ClassA @ 8W, the output stage must be able to output 1.414A of ClassA current.
- Class A/B switching?
