I have two pairs of 2SC3264 and 2SA1295 transistors and I intended to make with them a stereo class A amplifier rated at 50Wrms/8ohm with wide bandwind and higher Slew-Rate .
Does anybody have a schematic of such amplifier?
gili_flash said:two pairs of 2SC3264 and 2SA1295
That is only 2 devices for 1 channel.
50 watts in class A translates to a minimum dissipation of 110 watts, 55 watts for each device.
With proper heatsinks it can be done, but not recommendable.
The SA1295/2SC3264 is a higher voltage rated combo, used for high power amplifier output stages.
Shame to waste on a 50 watter.
Better would be to use a single pair in high bias class AB, something like 20/25 watts in class A and 50 in B.
See: Electrocompaniet
