CL08X2. Double 3FE25 full range, triple emission: direct, omnidirectional, multiTL.
The CL08X2 project adds two CL0800 satellites to the MDD3ZC350 V2 prototype, each channel has two Faital-Pro 3FE25 drivers connected in series.
The 3FE25 driver of the CL0800 satellite in a closed box has a first direct emission oriented towards the listening point.
The 3FE25 driver of the MDD3ZC350 V2 prototype has a second omnidirectional front emission MddOmni and a third rear emission with multiple transmission lines MddTL.
For each channel, 14 sound impulses arrive directly at the listening point without reflections. In MDD (Multi Delays Diffraction) technology, multiple, coherent, delayed and omnidirectional secondary emissions mask the unwanted effects of listening room reflections. The speakers also work well in untreated rooms as they generate the same effect as passive diffractors applied to the walls.
Thank for your attention
https://www.claudiogandolfi.it/cl08x2.html
https://www.claudiogandolfi.it/cl0800.html
https://www.claudiogandolfi.it/prima.html
https://www.claudiogandolfi.it/dopo.html
  • Thank You
Reactions: GM
