Cigar Box Class D amplifier
10 watt per channel TPA3122D2 IC mounted on a quality PCB. Nichicon Fine Gold power supply capacitors, Elna Silmic II output filter capacitors, Bourns low loss/high current output filter inductors, Dale & Vishay resistors, Alpha volume pot, gold plated RCA inputs. Speaker wire connections made via circuit board terminal blocks. I'll include a wall wart style 12 Volt power supply with this amplifier, but any DC power supply from 10 to 30 volts can be used. Fantastic sounding amplifier with efficient speakers of 94db or higher. If you use a triode amp now, you'll love this bugger.
$35 plus $15 shipping to U.S. addresses. Paypal Only please.
