Just for interest,
I have a few Ideas however, I would like to know if others have any experience with this!
I thought I would post a few things I have found "empirical research" I suppose you could call it whilst trying a few things with my project single ended.
Findings are that the value of choke seems (I say seems because some will argue, this is not slight its chalk and cheese) to effect the presentation of the music. The hum levels remained the same "Very low".
10H choke gives a warm almost sickly 2nd harmonic presentation!
2H choke complete change much less warm with details muffled and bass in your face! This would seem to say that the choke stifles the music?
Bypass choke with 47 Nano farad 630V cap vast improvement in bass, and detail.
This was followed by first PSU cap bypassed with polypropylene 0.1.
Cap after choke across 2nd PSU cap 2.2 polypropylene.
If I put a 22pF cap across the audio input detail increases again.
I just wondered if someone can put some light on this without having to try and measure the "invisible again"!
M. Gregg
M. Gregg
Hi!
It is always the whole PSU which interacts and not just the choke.
The choke forms a resonant circuit with the cap. If you change the value of the choke you shift the frequency of the resonance which of course can have a big impact. Discussing the choke in isolation makes no sense.
If you are bypassing the caps, you can have multiple resonant circuits in your PSU.
Do you know PSUD? This will show some of the differences. However it cannot simulate when you add caps parallel to the choke. Such things can be simulated with LTSPICE
Best regards
Thomas
Best regards
Thomas
Schema?
I am an olde tube geek (64, she still feeds me). Prose is OK, but, if I could see the schematic, it might improve my comprehension of your comments.
Happy Ears!
Al
Happy Ears!
Al
Hi!
Best regards
Thomas
I know PSUD. This was an observation from practical experiments.
Just for interest
Resonant-choke Power Supply
I am just looking at the choke Vs non choke PSU and effect on sound quality perhaps I should say "type". Because it seems to me the two are not the same sonically.
M. Gregg
Thomas,
Thank's for your reply, this raises other issues. Is there any research on PSU resonant frequeny and sonic performance of amplifiers?
Has any one done a check on Ongaku PSU resonant frequency and compared with others? I.E. what is optimal for sonic performance, because the DC voltages are very similar. So once the level of ripple is reduced to minimum we only have the AC pass frequency of the PSU.
M. Gregg
M. Gregg
Hi!
Each PSU will have different impact on different amplifier circuits. PP will act much different to PSU changes than SE. Also different output tubes will react differently. There is no easy answer like how PSU x will sound like in general.
Higher rp tubes are much more forgiving on the PSU, low rp tubes require a PSU with low Zout. I also found that output stages with an ultrapath cap react differently to PSU topologies.
Anything you find out empirically will only be true for the context you tried it within.
As for the resonant PSU: This was a 'trick' to get better filtering from the same size parts. It requires the cap and choke to be tuned to your ripple frequency. If it is just a little off, the effect will be reduced dramatically. I would not recommend such a scheme since it might drift from the optimum setting even if carefully tuned.
Best regards
Thomas
Best regards
Thomas
Fantastic article. I'll bookmark that one, and go back to read it over again a few times. I think I want to experiment a bit with those resonant supplies.
I don't belive any of the common considerations can explain much about the sound of chokes. Yet, same as capacitors they do seem to have some inherent "sound". I have a box full of chokes i just cannot use for any quality audio. Nothing wrong with their basic parameteres but irrespective of PS topologies or application they just don't sound any good. Even in preamps, being followed by high performance regulators.
Luckily i started using Lundahl chokes and they are a lot more predictable sonically than the random makes in the cursed box.
Are the different chokes you are comparing similar in construction? What you hear may have very little to do with inductance...
Oh come ON
The effect of a subsonic resonance in the PSU will depend, among other things, on the frequency and damping of the resonance. The frequency may interact with other relevant frequencies such as record warps, arm-cartridge resonance, mains supply voltage variations etc. Because of this, what works for one person might not work for someone else. When someone says "this choke is superior to that choke", all they may be saying is that this choke moves the PSU resonance away from my typical mains variation frequency, or it may modify the PSU damping provided by my particular amplifier DC load.
Interesting article on Resonant Choke filters! It might be fun to try a resonance cap across the first choke in a CLCLC filter to increase H2 rejection while leaving the second choke without to catch the higher harmonics.
For typical amp HT supplies, most available inductors have much higher inductance levels than what the resonant design levels would dictate - and using a higher level of inductance would lead to lower Q design, with the advantage that eg for a PP design, the idle current would probably exceed critical current level, and probably even out the magnitude of 2nd and 4th harmonics in the output. It would also lower the peak stress on the inductor and resoanant capacitor, which could be higher than one might expect - and indicates one practical issue which is how to get a microfarad or two at 1kV type levels.
I think it would depend on B+ value, also the damping effect of the Cap may reduce EMF I have used 630V with no issues across the choke. This was just "empirical" practical experiments. YMMV.
It's certainly interesting to hear the changes in sound with even small caps.
M.Gregg
The choke/capacitor voltage peak will be something like the output DC level. Given that the base LC resonant circuit only includes internal choke ESR damping, I would be wary of the ability that transients or step changes could lead to higher pks - maybe it is even better and simpler to use a MOV in parallel to the cap than just having something like 200% voltage rated caps. Most poly caps have reasonable transient over-voltage ratings that would likely work well with a MOV.
Ciao, Tim
Ciao, Tim
I think it is because each layer has it's own insulation. I.e. low capacitance? That you find these good.Luckily i started using Lundahl chokes and they are a lot more predictable sonically than the random makes in the cursed box.
Tim, is the concern for voltage ratings on the cap due to potential inductive kickback in the inductor? Would that be due to the charging current to the reservoir caps? Would that problem be less if the resonant cap were across the second choke in the series (less pronounced pulses)?
Mike, it's probably my sometime excessive focus on protection. A quick calculation of the energy in let's say a 10H choke carrying 150mA, with say a 0.25uF resonant cap, would simplistically cause a 1kV pk rise in cap voltage if external circuit current stopped abruptly. If a fuse was used in the ac secondary, or a valve rectifier failed, then that may cause such a step change - but choke current could well be much higher if say the fuse was pushed to failing due to an amp problem. Moving to a less damped LC would alleviate the situation as C would increase and L would decrease.
If the choke was clamped on both ends by a filter cap then they would help soak up any inductive kickback concerns.
These are just my cursory thoughts - I may be missing something bigtime!
Ciao, Tim
Ciao, Tim
- Power Supplies
- Choke power supplies and bypassing.
