Is this amplifier worth a try or is it just junk?
Can i use it as a replacement amp in a subwoofer Plateamp if voltage/current is ok?
Any ideas or should i go for something else?
Maybe some diy Class-D amp will do better?
https://www.aliexpress.com/item/100...216694111479612912e1aef!12000028507966479!rec
Anyone tried it?Hi,
https://www.aliexpress.com/item/1005004245379207.html?spm=a2g0o.detail.0.0.51c147ffwxjK1V&gps-id=pcDetailBottomMoreThisSeller&scm=1007.13339.291025.0&scm_id=1007.13339.291025.0&scm-url=1007.13339.291025.0&pvid=b19c6597-049b-4ee7-a97a-bff0f0c9f36f&_t=gps-id😛cDetailBottomMoreThisSeller,scm-url:1007.13339.291025.0,pvid:b19c6597-049b-4ee7-a97a-bff0f0c9f36f,tpp_buckets:668#2846#8115#2000&pdp_ext_f={"sku_id":"12000028507966479","sceneId":"3339"}&pdp_npi=2@dis!NOK!575.42!506.37!!!!!@2101f6b216694111479612912e1aef!12000028507966479!rec
Stereo...Can i use it as a replacement amp in a subwoofer Plateamp
I consider thisone to be a better alternative due to more possibilitys as +-15V and mute possibilityWhy not Connex or ljm l25d or l30d?
- Class D
- Chinese UCD Amp (worth a try or not?)
