Hello friends,
what do you think about this chinese amp ? i search for cheap kt88 amp..
thank you very much 🙂
Himing Rivals AK 88 Silver Prince KT88 Tube Amplifier HIFI EXQUIS Single Ended Handmade Class A-in Amplifier from Consumer Electronics on Aliexpress.com | Alibaba Group
I have seen it all now;
"2 Milliammeters independently in real-time display your power tubes emmsion values, assure your power tube have a good value, and chang the value if you want for a better "Overclocking"(do not recommande for junoir )".
Don't think I would spend my money with a company that cannot even use a spell checker let alone use capacitor clamps instead of tie wraps!
The last two Chinese FU29 amplifiers that came in for service whilst almost new had the mains neutral connected to the chassis. Extremely dangerous! Purchase if you must but only if you are a competent electronics engineer with a full background.
In that case, I would stay well away and purchase something from a supplier that conforms to basic safety rules and meets the regulations for your country.
Thank you very much JonSnell .
i saw another KT88 , is it the look better or all the chinese app are the same ?
Nobsound Hi end KT88 K1 Vacuum Integrated Tube Amplifier Stereo Single ended Class A 2.0 Channel Power Amplifier 15W*2-in Amplifier from Consumer Electronics on Aliexpress.com | Alibaba Group
The build quality looks a bit better. If you do purchase this, ensure you use a credit card or PayPal to pay for it for added consumer rights protection.
I would not mind to buy the bluetooth version. The Chin-glish and neutral attached to the chassis are not relevant here.
I think here they translate it correctly , its look same amp...
Douk Audio Latest KT88 Single ended Class A Tube Amplifier With USB decoding Upgrading of Computer Sound Card Sound quality-in Amplifier from Consumer Electronics on Aliexpress.com | Alibaba Group
Joined 2009
So what to buy -
the first one - LaoChen
or second one -Himing Rivals
LaoChen K1 KT88 tube amplifier HIFI EXQUIS AIQIN OCK1 handmade scaffolding OldChen Audio amp-in Amplifier from Consumer Electronics on Aliexpress.com | Alibaba Group
I have not really studied the Chinese amp scene because my interest lies in DIY and refurbishment of classic tube era designs but my basic philosophy is that one's capabilities in recognizing design and build faults and correcting them should be in line with the risks one takes on products of unknown or suspect quality.
If you are not particularly skilled then I would go with amps that have a clear track record of being of good quality and/or with known simple modifications to be made so (some searching here will likely turn up good candidates). The more people that have experience with a particular amp the more likely you will find success in the end due to that knowledge base.
I will also note that a good KT88 amp is not an inexpensive proposition. The tubes themselves are not cheap and they are quite muscular (anode dissipation can be in excess of 40W) requiring some substantial parts to support them such as fairly sturdy output transformers, power transformers etc. Thus a very low price amp is likely to have skimped somewhere. I built a SE KT88 amp using decent quality but not top of the line parts and I would say my investment including using salvaged chassis and power cord was solidly north of $400. I used Edcor power and output trannies along with Hammond power supply chokes. Tubes were new production (mostly Russian). I used decent quality but not golden ear Poly caps throughout and mid priced electrolytics for power supply. It sounds really nice IMO but a slick looking commercial product for 25% less seems suspect to me.
You should at least stretch your budget to get something like a Yaqin. These low budget Chinese amps don't come anywhere near published specs, and when you buy something like a Nobsound product, your likelihood of getting counterfeit parts increases.
If you're on a budget, a Magnavox 6V6 console tube amp can be purchased for not a lot of money.
Thank you very much mashaffer 🙂
do you think the bass in EL84 will be KT88 amp ?
the reason i want KT88 it's because i read that KT88 can provide good bass.
That is a misunderstanding. Bass ( or treble) is equally well in tubes, it depends solely on the amp, circuit and transformers.
- Tubes / Valves
- Chinese KT88 amp
