I was wondering what the best all around tool for DIY speaker tweaking is in both
DIGITAL
and
ANALOG.
I have built a 4way system and had the basics of the crossovers built and now I was wondering what tools to look for from this point on.
I have a 2496 i picked up a year ago,but was wondering what else
Analog-(Ossiliscope-what one?,etc.)
Digital-??
thanks guys
DIGITAL
and
ANALOG.
Digital-??
thanks guys
Fuzzmeasure 3
- Dayton EMM-6 calibrated mic from Parts Express (only $40 !!)
- an inexpensive but decent usb mic pre-amp like the A.R.T.
The above suite will give you some very powerful measurement tools for little outlay.
- Fuzzmeasure 3 running on a MacI was wondering what the best all around tool for DIY speaker tweaking is in both
DIGITAL
and
ANALOG.
Digital-??
thanks guys
I agree with Jack that the Dayton EMM-6 is your best deal for a measurement microphone. The Behringer ECM8000 is very similar in design and price. Coincidentally, I'm also using the A.R.T. Phantom I power supply.
I hate to say this, but I think you should build a Wallin Jig, and download Speaker Workshop. The Wallin jig is just a box of switches and resistors which makes measurements more convenient. Here's the web site: Eric Wallin's Internet Homepage
Speaker Workshop is about the most frustrating software I've ever worked with, especially when used to take measurements. Mr. Wallin's tutorial is not very helpful because it is written specifically for the modified soundcard he was using at the time, and will not be applicable to any other sound card. However, if you persevere, and figure it out, you will have a very powerful design and measurement software package for free. Driver testing, T/S parameter calculation, box and X-over design and speaker measurement are all integrated in one program. I've also gotten useful help on this forum with S.W. so don't hesitate to post questions when you get stuck. After I figured out S.W. I learned about a different manual, here: http://www.esnips.com/web/SpeakerW/
I've not read it, but it may be better than Mr. Wallin's tutorial.
I also recently downloaded HOLM Impulse. I've heard good things about it, but not played with it yet.
Good Luck!
Good Luck!
I just tried to download the S.W. manual from esnips and it wanted me to install some software and create an account so I decided it's not worth the risk. I'm not endorsing esnips.
I also use Fuzzmeasure, but in addition to that, I wrote a lot of measurement and analysis software myself. IT's free and works exactly the way I want to.
Sheldon
Sheldon
I use Fuzzmeasure as well, and have cheap Beringer & Dayton calibrated mics and Edirol FA66 Firewire ADC/DAC.
Room EQ Wizard is free & dual platform.
dave
dave
...but it is for a MAC. Is there an equivalent for a real computer?
Usually that's what the Mac guys say -- OS X is proper UNIX after all.
It is far too hard to support Windows if you are only 1 guy... much easier to write & support this kind of software on a Mac.
You could look at Arta. I'm going to be trying that under CrossOver Mac or XP under Virtual Box just because they do a proper waterfall with Periods on the time scale.
dave
What the Wallin jig does the Dayton Woofer Tester does better and faster, especially with the version 2 of the software.
I now have a dual boot macbook so I can use both Windows and OS X software 😉 I really have to get that fuzzmeasure...
There is also Claudio's tutorial (I haven't used it but he helped Jay with the Unofficial Speaker Workshop manual (Claudio was the person who uploaded to esnips I think). Esnips didn't originally require you to install software to download it. http://www.claudionegro.com/download/SW%20tutorial%20ENG.zip
I have a copy of the 2nd edition of the Unofficial Speaker workshop manual. It is 18MB so I think it is well past the limit that I can attach (and it does have a copyright message at the begining so I shouldn't anyway).
I've PM'ed Jay (the author) to see whether I would be able to upload it somewhere where it can be downloaded without any hassle (I think I have 100MB of web space with my ISP account). I gave some input to Jay for the 2nd edition http://www.diyaudio.com/forums/mult...ting-speaker-workshop-manual-2nd-edition.html
Also the thread I started when I was having problems I think has some good info in it as well 🙂 (from other people 😉 ) http://www.diyaudio.com/forums/multi-way/62568-problems-acoustic-measurements-3.html
I actually now do my measurements in holmimpulse export and import into speaker workshop to do the crossover modelling. Holmimpulse seems to give me more consistent results for impulse measurements that I was able to get with SW.
Tony.
Tony.
I Got the OK from Jay (Thanks Jay!) 🙂 so I've uploaded the unofficial speaker workshop 2.0 manual to my Webspace:
http://home.exetel.com.au/wintermute/diyAudio/sw_manual.zip
I might make a proper page of it a bit later.
Tony.
Tony.
Hi Tony,
yes I placed on esnips Jay's tutorial, otherwise my HP would run out of space. I wasn't knowing of the new requirement for downloading from esnipes.
May I place the link on my HP to your webspace for downloading the file?
Claudio
Claudio
If you are going to get a woofer tester i'd recommend the original.
woofertester.com
dave
Of course Claudio! no problem at all 🙂 I should also have suggested that people have a browse around you site too! I would have posted a link to the downloads page rather than the file direct but couldn't see the url (assume you are using frames or php or something) 🙂 http://www.claudionegro.com
Tony.
Tony.
What is the actual cost of the above mentioned set up guys ?
If I already have a Mac computer that is ?
are softwares hard to use once installed ?
Can you get a free copy to try this ?
cheers
cheers
- Design & Build
- Equipment & Tools
- Cheapest(best) speaker measuring tool
