Cheap, variable, dual rail supply for amp testing?
I've been 'hooked', and testing many different amp boards lately, but I'm missing some kind of variable stabilized supply for this, to be able to adjust the supply voltage to the specific amp, and maybe also measure distortion performance depending on supply voltage.
I think I saw XRK mention something about some cheap variable dcdc boards somewhere, but they were only single rail, and I don't know if they are isolated so they could be staggered to a dual supply.
Input voltage can be 240VAC or dual/single supply from some linear PSU I already have (a few). Output.. maybe +-12 to +-50V and min 5A..
It should however not involve making my own PCB's or similar, since I don't have the equipment for this. I prefer 'click and buy', hopefully from a European source (slow and expensive to get china-packets through customs here nowadays). Nice price is important too 🙂
Hope you have suggestions!?
I just use a good simple linear power supply (dual secondaries 200VA transformer and decent filtering capacitance) with a Variac in front. Its relatively cheap, very flexible, and lasts almost forever.
If you already have a linear PS, you just need a Variac. You can keep the voltage stable by adjusting the variac as you load the amp under test.
You could probably get away with a +/-35 volt supply.
That would cover a lot of chip amps and a lot of discrete amps.
It obviously wont give full power on something that needs +/- 70 v rails but at least it can power it up enough for testing.
I have a test rig similar to that, an addition was speaker DC protect on output, just in case. The power, input and output are all on croc clips for easy connect.
Thank you for your replies!
I think I have some transformer where the secondaries can be split, I have to check that!
Do you have some suggestion on decent DC-DC's?
Variac would be nice, but kind of fall out of the cheap-category..
I have been using a +-37VDC supply, but testing class A usually means lover voltages. Also testing heavy bias on AB amps requires lowering the voltage. This is where the variable voltage would be nice!.
Some sort of current limiting is essential for testing amplifier designs, otherwise 100's of watts are available to burn up a faulty circuit instantly. The cheapest way to do that is add some switchable series resistors to the outputs.
There must be some designs out there for variable voltage, variable current limit regulators?
At a push, some well selected resistors will do the job for safe powering up of amplifiers.
I've got a 0-30v 0-3A linear limited constant voltage / constant current supply on my bench.
I bought it from AliExpress but the TL07(8?)1 chips were fake and burnt up. Once I swapped them for good ones and identified and replaced a bad zener diode... it worked fine. As a precaution, I replaced the transistor with a proper one too.
So the design at least, most of the components, and the PCB, are good. 0-30v 0-3A (it goes over 3A actually maybe it would do 5 on the right transformer). Needs a heatsink but with that it will cope with a dead short at full steam (100W ish) at least for as long as I was willing to try.
Paired with a digital voltage + current meter it does the trick and it was pretty cheap. A few sellers have them and you might get lucky on the opamps and transistor, but I'd count on replacing them, they're not exotic or expensive. I've got a second kit and a dual secondary transformer there to let me build a split supply when I get around to it. I ended up padding the current pot to get better control at lower currents.
0-30V 2mA-3A Adjustable DC Regulated Power Supply Diy Kit Short Circuit Current Limiting Protection Board Module For Arduino
AliExpress
For a little more money there are some rather good microcontroller "lab" supplies available prebuilt, the DPS series with ratings from 30V/3A and up. EEVBlog gave these a favorable review and there are others online.
Third, if you're made of money, or get lucky, pick up a proper lab / bench split supply.
I would not bother trying to use those small one-chip cc/CV modules for this, they're really only designed for battery charging with a protection circuit inline and well below "rating". Things like dead shorts or reverse voltage will make them (literally) blow up. I had one blow bits of ceramic out and burst violently into flames on my bench once after I "accidentally" it on a 500Wh E-Bike battery [emoji23] damn near crapped my pants
Thank you for your input!
I ordered two of the '300W-boards' in the link above. They seem to have an adjustable current limiter. Guess I have to wait and see how they perform..
Until now I have been quite aggressive connecting things, and lucky most of the time 🙂
I have access to bench supplies at work, so sometimes when there is a little bit more money or time involved, I tried them at work first. However, it seems not many bench supplies have high enough dual rail voltage + current.
I hope they work out but they do look like they're designed for eg. Battery charging where there's a steady draw, and may not limit current instantly, in the way you would like. I'd test one into a dead short or a small value load resistor with a low current set and see what it actually does before trying to use it. My 2c.
I received the boards and tested this with a 5ohm resistor, and it seems fine. Delay varies depending on the set current limit vs actual current, 10-30ms delay with the settings I tested. I think a fuse would not do better.
Ripple seems ok too. Maybe something I could use instead of a massive capacitor bank on a class a amp..
How about something linear, with traditional transformer?
A voltage source / current source?
Any good designs with precision voltage setting between 2V - 60V
and with the possibility of fallback into current limiting mode, 0 - 5 A,
but with this current limiting mode also with precision setting capability,
so that it could also be used as a "current source"?
... In view of the fairly cheap readily abundant readily available Chinese universal laboratory voltage power supplies, does it make any sense to considering building one by oneself?
Most of the Antec transformers have dual primary and dual secondary windings. Two such transformers can provide a multiplicity of configurations satisfying most power amplifier supply rails by putting the primary in parallel or series.
For power amplifiers, regulated supply isn't necessarily good for testing output stages -- the regulator can put its own signature on the supply rails.
Me, I have a big Variac bought from a fella who used it to power up his air conditioner when Jersey Central Power and Light had one of its frequent brown-outs.
