Cheap subwoofer driver isn't
diyAudio Member
Joined 2007
A FaceBay sale and I just collected. I thought it was worth taking a chance on a 20 minute drive and a $20- sale.
One of them is a decent enough generic 10" 4R woofer but the other.
It's a Paradigm in excellent condition.
Looking now for any information on the Paradigm B156 WFP Also note some extra numbers on the sticker W02200
Cast alloy frame and a poly cone with stiffening ribs and about 15mm of travel. Dusty and needs a clean but measure 8R
Hmm, for some reason thought you had a DATS, but memory's fading fast; someone posted about a BoFu, which I have literally decades knowledge/experience of plus [6] in the closet, but had to go look them up online to 'remember' this. 🙁
Regardless, unless someone pipes up or Paradigm helps.........that or the pioneer's standard 5 ft^3 tuned to Fs or whatever sounds best in room using a ~Sd/3 vent area.
I hear ya except add repeated years of storm damage not covered by Insurance because I can only afford very high deductibles and why my audio system beyond through the TV has been MIA right at 20 yrs now. 🙁
Played some low volume music through the driver free air. it has a buzz, I guess when the subs amp blew up [ which is why the drive was so cheap] it heated the voice coil and now it rubs. I'm not sure I can use it "as-is" and it will go on the shelf to think about a repair when funds permit. Ditto the other driver; I wonder how loud this system was turned up when the subs died??
Still while $20- is $20- it was a nice day for a drive and only used a few dollars worth of fuel.
