Can anyone tell me if this will work?
http://www.aria.co.uk/productinfocomm.asp?ID=9837&SpecialStatus=1
From AriaPC pages:
>>What are the viewing angles, contrast and brightness?
>>By Bob Nicholson on 01/03/2005 11:36:54
>>Rob D replied: (01/03/2005 12:39:51)
>>160 degree (H) 150 degree (V)
>>450:1
>>250cd/ m2
This monitor propably has the same panel as BenQ FP567s v2?
>>450:1
>>250cd/ m2
good specs
The contrast ratio & response time are good for a 15" monitor. The only question is, can it be stripped for projection? If nobody else has had a look, then you get to be a pioneer!
Pioneer: That fellow way out front, with the arrows in his chest.
Unfortunately, the website of the vendor says they may change brands without even telling you, but the specs will be the same. That does not mean the substitute brand will also be strippable. That is not one of the performance specs!
I got the digimate someone mentions in the review, not too bad to strip, but FFC issues.....I managed to crack it 🙁 , but that was 'cos I was using a rubbish screwdriver and I had to pop a screw out.........Too many dead pixels for my liking also, but they do make that clear in the description.......450:1 contrast rocks for projection 🙂 🙂 🙂
